Yeh the engine is, everything else seems to fight over what wants to v the weakest link.
But in my case the engine decided to fight as well, spun an awesome bearing
Put it this way, I sold with without an engine.
$10 says you sold it cos it needed an oil change
From this:
To this:
Notbad.jpg. Feels a lot nice to use. Is a bit smaller too so helps with my long lock to lock when parking.
SRS light is on though, cause i turned it on without the airbag to see if it was straight. Now to find out how to reset the srs ecu...
I would assume same as Skyline. Remove earth from battery, pump brake for a little bit so all residual power gets used up, then connect it all up again.
http://www.youtube.com/watch?v=FpWwvWgQ0o4
Came across this board when I was browsing through youtube. Get's a bit repetitive after a while but gave me a couple of laughs. Watch if you're board and have nothing better to do with your life....*sigh*
well if you spun a bearing...you would ahve to change the oil after that..taking the engine out to change oil was probally a little much, and being too lazy to put engine back in as it fell down the back of the couch...
so yeah oil change it is ;)
front lower ball joints cannot be replaced separately, the whole control arm has to be changed. uppers too 500$/control arm?? i dont think so.
Saw the up to the Mario Kart bit and was like wth.... as if they would use Mario Kart and air it until i read the description... lol
Aaron!!!
I got my GoPro3 Aaron edition today! She's such a black beauty!
Know anywhere to buy the suction and pole mounts for cheap?
keep the standard kit on the sedan steve, some 10+15s at the rear and slam it.
i test drove a 6 speed na supra for a mate, was reasonably quick for what it is, but the thing i fell in love with was the gearbox!
Aaron!!!
turn the tables on aaron and steal his ones, bet that nigga wont expect a white boy stealin his shittttt
Dow shift is Asian, Teds usually stocks them, as with Harvey Norman, but I got mine off the site and combined the shipping
And make sure you update it before using it, otherwise it locks and its a pain to reset
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
