Yeh the engine is, everything else seems to fight over what wants to v the weakest link.
But in my case the engine decided to fight as well, spun an awesome bearing
Put it this way, I sold with without an engine.
$10 says you sold it cos it needed an oil change
From this:
To this:
Notbad.jpg. Feels a lot nice to use. Is a bit smaller too so helps with my long lock to lock when parking.
SRS light is on though, cause i turned it on without the airbag to see if it was straight. Now to find out how to reset the srs ecu...
I would assume same as Skyline. Remove earth from battery, pump brake for a little bit so all residual power gets used up, then connect it all up again.
http://www.youtube.com/watch?v=FpWwvWgQ0o4
Came across this board when I was browsing through youtube. Get's a bit repetitive after a while but gave me a couple of laughs. Watch if you're board and have nothing better to do with your life....*sigh*
well if you spun a bearing...you would ahve to change the oil after that..taking the engine out to change oil was probally a little much, and being too lazy to put engine back in as it fell down the back of the couch...
so yeah oil change it is ;)
front lower ball joints cannot be replaced separately, the whole control arm has to be changed. uppers too 500$/control arm?? i dont think so.
Saw the up to the Mario Kart bit and was like wth.... as if they would use Mario Kart and air it until i read the description... lol
Aaron!!!
I got my GoPro3 Aaron edition today! She's such a black beauty!
Know anywhere to buy the suction and pole mounts for cheap?
keep the standard kit on the sedan steve, some 10+15s at the rear and slam it.
i test drove a 6 speed na supra for a mate, was reasonably quick for what it is, but the thing i fell in love with was the gearbox!
Aaron!!!
turn the tables on aaron and steal his ones, bet that nigga wont expect a white boy stealin his shittttt
Dow shift is Asian, Teds usually stocks them, as with Harvey Norman, but I got mine off the site and combined the shipping
And make sure you update it before using it, otherwise it locks and its a pain to reset
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
