yeah it doesnt worry me cos its my dads
he loves recording free to air stuff so he can put up with the ass features =)
ive got two wd tv live's in our house
bulletproof and plays every movie
ive even got two cisco switches now so its a pretty good setup
14 active ip's in my house =)
About to watch The Hobbit...
Watching at Doncaster shopping town... A note to any low brahs... Go up straight to multilevel. f**k the area outside the cinemas. Speed bump + humps are like freaking spikes in NFS, dat scraping :(
Wait till you go down the exit ramp bro. Scrapes like a mofarkin hustler.
Always get scared of the ramps in the Kings Way carpark at crown...never scraped once though. Deceiving.
Wilson's Parking on the other hand...owe me about 5 or 6 front bars.
Yeah, it's bad up there. Hadn't scraped on any of cars I now have and had.
Good thing I don't have to park all the way up all the time since xmas is over - easier to get parking closer to work.
I'm not too far from franga maybe I can pick one up for you?
Let me call them directly tomorrow and check if they have it, then I'll collect it from you at go karts. :thumbsup: That reminds me, i need to pay for that!
So.
I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee"
and i'm going in full formal, is that a right decision? tie blazer and all dat.
Intern at HR company hide all peircings and that butterfly tattoo.
but in reality your going for a job at a i'm assuming professional company, you should suit up as ther a good chance that what you will be wearing on a daily basis.
So. I'm going to be having an informal(perhaps) interview at a HR company for my internship, ceo said "lets have coffee" and i'm going in full formal, is that a right decision? tie blazer and all dat.
http://youtu.be/6Dtn4kP7lrA
So.
Is it a city job?
Suit up bro
Like Martin said likely you'll be wearing that everyday
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
