Just do dinner I been with the missuz nearly 7 years ain't celebrated one single anniversary saving that shit for marriage
I'm with you on that. And my Missus agrees too. Anniversaries are for marriage
22/1-year anniversary. (but we've recently moved in together, so not some chump relationship)
Maedaya in Richmond looks good... and i do love hot sake
I think i'd get carried away at Nobu. sea urchin sushi would be a must, plus like everything else on that menu
This place does a good Japanese stonegrill, it's small and intimate: http://www.ishiyastonegrill.com.au/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
