So she's even less attractive than she is in that photo?
Liking the rims on that 380
Yeah that was a geek challenge to dress them up n shit I think
She is attractive in real life, ran into her randomly /stalker
Edited by UNR33L
oh okay, been hearing people say that the petrol will go stale and lose ron.
Cheers Martin.
it will but not in 2 weeks.
think of how many people go 2 weeks between refills
I've got a older 97 Falcon v8 on a mates property
put battery in it after 12 months still ran, that fuel is maybe 2 years old
wouldn't put that in my track car but still runs.
So by the petrol going stale, are we talking a duration of months?
Well the weather is like in the higher 20's reaching to mid 30's from now till next week.... low 20's is perfect imo.
If you've got a hard set tune which really doesn't allow for any leeway with the ron of your fuel, then wouldn't be loading up the engine if its been off the road for a few months. But driving it down to the servo to get some fresh fuel into it will be fine.
Don't be letting it sit with a full tank of petrol for months and months though, since if a track day comes along and you've got a full tank of old fuel, you're going to gave a bad time unless your drain it out.
Also, I wouldn't be trusting Stale Fuel + Octane booster... Really not the same thing as fresh fuel ;)
What advantage is having a iPad mini instead of a regular headunit?
Don't you just use it to play music?
It's not like your going to browse or watch videos whilst driving?
Maybe using GPS & Maps?
Maps
Evo scan(tuning/diagnostics)
Go pro controller
Lap timing
Internet if I really needed it
And something different
I just emailed carbon34 about the custom dash which he's making for me. Should sit flush!
grats on getting it done man
i saw this one the otherday -
I like how behind they have the normal sony headunit still
Yeh heaps of cars have dash's that are available off the shelf, but I'm struggling to find anyone that has actually done it to an Evo 7/8/9..
Lol I like to think I'm first
    • hello wanted some insight on what my problem could be so i swapped a RB26DETT into my r33 gtst used a R33 GTR engine harness and im using a haltech platinum pro. The car cranks but no start the ecu isn’t getting any power now im trying to find out why i cant seem to find any schematics  or diagram for the engine harness for the r33 gtr anything helps thank you.
    • hahahaa @GTSBoy that is my last resort. Like use a cardboard and cut it using the indicator as a reference. But I was winging my luck to see anyone had a spare bumper because drawing the outline off the hole is always easier and less chance of mucking it up
    • Admittedly in that screenshot its doing about 13psi but later on in the log theres definitely spikes to 16. What is missing though is the massive peak, then a big drop and then a recovery. While it does go a little higher than I would like on base pressure, I think it's reasonably safe to assume that boost control via the mac valve should be a lot easier to control from here on out. I wasn't game to hook up the mac valve today as it's very wet and it's on the verge of fighting traction as it is.
    • I think this is still wrong. There is something crappy with wastegate priority (or the f**king absence of it) if you can't get below nearly double the base spring pressure. But if you're happy with what you've got, upload skid vids now.
    • So a further update for this one. Turbosmart were very gracious and took one look at the wastegate and said this is our original version, we will just replace the entire thing and send it back to you. So I fitted the new wastegate with its new revisions and took it around the block on spring pressure (9 psi spring). Appears the minimum it will do is about 16psi. Keep in mind this is only 2nd and 3rd gear pulls. I think the issue is fixed compared to what it was doing before however I'm happy to provide more logs if anyone thinks theres more to the story to uncover
