he would have man... but i am unaware
if you search "lams" on evolutionoz.net you will find a 10 page thread on it
cbf, need a full RWC just to view that forum.
Might peruse Carsales.
4 doors, newer, more comfortable. But unsure about comfort factor...was riding in Aaron's the other day and I rate my Skyline for better comfort. I do like the cushy lounge style seats of the 90s.
The front would be comfortable for your skinny ass
To be honest I find it pretty comfortable, but I'm coming from a small car extremely hard to get out of
2lt is not a problem at all birds...
given the gearing and diff ratio, my evo has basically the same amount of lag and almost the same length powerband my 33 had
feel free to drive it any time
You forgot to mention half the power lol
yeah, there's that too :/
i'd say that given drive ratio's and diff... evo's need slightly less power to be quicker in the lower gears..
i'd estimate evo 200 feels about the same as gtst 230...
not to mention that in the wet i have 700 times the power now lol
And if you're driving it on the street, lower gears is where its at... Who gives a flap how it pulls in 4th/5th/6th if you're not on the track...
exactly... but the way the 33 pulled from 150kph + I AM GOING TO MISS
I beg to differ, I wAs keeping up fine with the 240kw plus cars down the straight at sandown. It's a very under estimated car
Given above 150kph, is when they start to pull away
Even gave Scott a run for is money in the 350kw Stagea. He only pulled away at 120kph.
Hence why he bought one lol
I want to see this first hand. Not saying I don't believe you
Tonight
Your car vs say Simon/Birds
Roll on from say 70km/h. That's about the exit speed at Sandown onto the coming straight
from what aaron has said about this sandown trackday i'm beginning to think that semma didn't die that fateful day... he just got badly burned and decided to go into hiding as a srilankan collections worker
What? Who's semma
Tonight
Can be arranged. Although I have it on video with the go pro lol
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
