whats fast/fun, four wheels, <5k and not a nissan? kgo
90s Prelude or Integra...
But if you don't mind old, one of the greatest / most fun cars I've ever driven, was a 1989 Prelude. Would buy one brand new if I could. So comfortable/functional, so much visibility over the bonnet (like a Porsche) and they handle ridiculously well (beat out Ferraris and Porsches in a slalom at the time).
Anyone who has driven one will tell you, the four wheel steer is awesome...none of this HICAS shit, it's actually useful. You can turn into a carpark on a 90 degree angle and going around round-a-bouts feels like you're in a boat (good way).
have driven both those hondas before and i agree with birds. haven't driven the mx5 or any kinda bmw so tossing up b/n those two atm.
this is just to tide me over till subaru decide to officially strap a turbo to the brz
5 min on carsales
http://www.carsales.com.au/private/details/bmw-325i-1990-12003526
shame about the colour.
http://www.carsales.com.au/private/details/mazda-mx-5-1997-13955834
will keep kicking this idea around but i reckon i should just go travel instead
Alvin, you still need old computer stuff? I've got 2 old printers, like some multifunction or something along with a hub and router. If not, do you know any recycle computer places in the west side? Forgot it was garage cafe tonight... :-/ So what's the verdict, emo or skyline???????
no printers, only agp/pci cards and cpus.
Hey Aaron did you say that you have a Walbro 400? Trent reckons my 255 is dying like all 255's do...
If so, age? condition? price? can I pay in wristies?
12 months... Stock -> 040 -> 040 -> 255 -> 400
lol bet you wish you could be apart of that ad!
The last guy must be super guy, "I love dickS"
btw you planning to go to that jdmst meet after gokart?
haha the old lady, "I know the only dick im getting this aus day"
lol probably not, but if you all wanna go ill tag along..
We should rock up in stanced go carts with type r badges all over them.
/cartlines
lol
age? NEW
condition? new
price= i think they are $160 new which is what i paid.
$130? take it aawayyyyy
MX5 will leave you broke...
my mate's (which is baller) cost him 10k and he has spent another 10k with the engine still stock....
car has too much potential
Done.
Need before Saturday, what time do you normally get home / or are you planning on passing near Vermont any time before then?
6ish? It's at Scott's place so I have to grab it off him first, but I can do that on the way home today
Whats the diff between 7 and 8 and 8mr turbos again?
What boost do they run at stock?
Drove Aarons last night, sure as fuark doesn't feel like a stock car, dat pull in low gears <3
7 turbo has a smaller rear housing than the 8MR turbo, thats all the difference is, but its cheaper to buy a second hand 8MR turb, than a new housing lol.
i think 16psi? nick will know.
Where's scotts? Might be on my way home as well ;)
hampton park.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
