yeh butthurt a lot of people from a 80km/h roll on, usually let them have first throttle push :D
to put it in perspective my brothers gtst had 255rwkw did a 12.9 i had 253rwkw did a 12.7 with roughly same mph dat torque and gearbox, also I'm willing to bet i'll get over 400rwkw on the Chasers dyno in a few weeks at a dyno day I'm attending seeings as I got 290 standard on it last time loool
my brothers now 340rwkw (on trents hub dyno at least..) car still cant pull on me, dat dere turbo lag vs supercharger
Edited by UNR33L
that 12.7 is more launch related. what was your MPH?
for reference i did 12.9 @ 119mph
/dat stiff coilovers
still my launch was only a 1.9 60ft think my brothers was 2.0 60ft. mph not too sure cant remember 110-115? turbo falcons get higher mph due to power delivery being midrange, my power curve is purely straight up so more revs = more power
these cars have done 10s without a intercooler :D, best tune only one i've seen is 11.3 with slicks
the GT500s in america are even more ridiculous, make like 440rwkw from factory
Edited by UNR33L
Less power and narrower band, why would you expect him to pull away? Still a good effort against your car I reckon
Gotta get me some e85
At ~250rwkw Leigh had 1.5 car lengths on me in a rolling. I'm confident I could keep up with him once I E85.
Where Leigh's car is faster than a Skyline of similar power/weight, is making that power much earlier in the rev range. Auto gearing helps too, depending on speed you drag at.
usually i'm still pretty far ahead especially at lower speeds, dat auto gearbox his car pretty quick when its running properly, unfortunately not very reliable these days lol
True, still I need to rev mine out next time :P our gear ratios would be heaps different - agree though responsive skylines are better
quickest car i raced was a done up f6 i reckon, we were flying for ages haha
that 2.7l rb25 wolf3d white r33 would take me easy, hit a 10 on last years drag day
Edited by UNR33L
Was it him who kept busting fuel pumps? I'm worried about blowing something up if I convert, about to tick over "150, 000kms" lol
Yep, that, turbo gaskets, intake manifold gaskets and few other things, split his intercooler pipe somewhere too i think at some stage lol
not to mention it leaks oil like a bitch now too
Edited by UNR33L
I know its a few pages back
But how is his surname actually spelt,
Pettet
Pettite
Pettit
Can we get a poll going on ? cause everyones doing it differently. Also has he got a wife? cause i know of a pettit somewhere in southeast. :P
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
