Rb20 feels slow now. Hmm
cos it's stock phaggot
chuck on a bigger kando turbo, highflow the injectors, etc etc and raist the limit to 9000 (or even 9001 so technicnally it's over 9000) and drive it till it pops. get trent to tune it so it lasts a little while longer
you wanna replace it anyway... might as well have epic fun with it
you'll have a fkn ball untill then.
for reference, tim's micilour 32 was 260 rwkw and limited to 8500, and anyone that has seen him drive knows the true definition of abuse.
3 or 4 years now if i remember correctly
moh....
this is from the kando thread....
lol, if you want cheap and goodv i have a new kando td05h-18g...will make the power you are after and be pretty mega respoinsive. you just need to buy bthe exhaust housing fo $150 and you have a $600 brand new turbo to givev fabricator to mount gate on housinhg
dooooooooooooooooooooooooo eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
easy...
F A G G O T
haha yeh true, my only experience has been like 10kw off racepace roller dyno, i know for sure that the SAU dyno day last year was reading way high though made over 30kw more on that stock than my stock run at my tuners, still always butthurt people complaining 'low dyno bro' I'll be back for my 400 :Dhttp://www.facebook....57935571022298/
on another note, f*kn massive headache this morning never again!(until next week)
Edited by UNR33L
yeah, I don't doubt that the chasers one is usually a little high... i've seen that a few times
lol yup!
not finished yet, so far it's just the cursive script in black on my inner arm.
next is a couple of blue and black swallows next to it
Sounds good, pics when done
Also get on it, cheap
http://www.catchoftheday.com.au/smallfish_info.php?event_id=2851
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
