Rb20 feels slow now. Hmm
cos it's stock phaggot
chuck on a bigger kando turbo, highflow the injectors, etc etc and raist the limit to 9000 (or even 9001 so technicnally it's over 9000) and drive it till it pops. get trent to tune it so it lasts a little while longer
you wanna replace it anyway... might as well have epic fun with it
you'll have a fkn ball untill then.
for reference, tim's micilour 32 was 260 rwkw and limited to 8500, and anyone that has seen him drive knows the true definition of abuse.
3 or 4 years now if i remember correctly
moh....
this is from the kando thread....
lol, if you want cheap and goodv i have a new kando td05h-18g...will make the power you are after and be pretty mega respoinsive. you just need to buy bthe exhaust housing fo $150 and you have a $600 brand new turbo to givev fabricator to mount gate on housinhg
dooooooooooooooooooooooooo eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
can we quit this faggotry about hub dyno's reading higher please? i'm soooo over it! they are better and more accurate... it's one dude in adelaide that bullshits his figures and happens to have a hub.
trent's dyno is callibrated correctly and runs the appropriate correction mode.
cars on trent's dyno make the same power as on a dyno dynamics in shoot 6 mode
my car was within 10kw of 2 different dyno dynamics rollers
easy...
F A G G O T
haha yeh true, my only experience has been like 10kw off racepace roller dyno, i know for sure that the SAU dyno day last year was reading way high though made over 30kw more on that stock than my stock run at my tuners, still always butthurt people complaining 'low dyno bro' I'll be back for my 400 :Dhttp://www.facebook....57935571022298/
on another note, f*kn massive headache this morning never again!(until next week)
Edited by UNR33L
yeah, I don't doubt that the chasers one is usually a little high... i've seen that a few times
lol yup!
not finished yet, so far it's just the cursive script in black on my inner arm.
next is a couple of blue and black swallows next to it
Sounds good, pics when done
Also get on it, cheap
http://www.catchoftheday.com.au/smallfish_info.php?event_id=2851
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
