Wow, top bloke on a shitty sounding GSX600 trying to race me in the Skyline...fk off I know your bike is quicker. Funny thing was, everytime he tried to get ahead in traffic, he had to slam on his brakes cause of his noob riding and he got no further than me just cruising along at the speed limit, minding my own business. Wish I had a chance to tell him he wasn't impressing me, just hurting my ears and that my bike is faster top bloke.
No bright lights no fame
HEY!
Caviar or champagne
She wanna be a plain old jane
She likes the taste of my sugar cane
Was the song playing at the pool bar! This place is f**king awesome so relaxing and fun!
Just finished a 3 hour jet ski safari to the beachcomber party island and did snorkelling there! Jess fell off the jetski and pulled me off with her when we were about to get off
Seriously not wanting to go home tomorrow!
Denarau islands! Highly recommend it here!!
Simon, change your booking :P
HEY!
Caviar or champagne
and pulled me off
pulled me off
pulled me off
pulled me off
pulled me off
pulled me off
pulled me off
lol sexe taimz
You idiot, something you would enjoy here are the restaurants! There's this place here called "mamacita's" I don't think I've ever had a better burrito in my life
And man, Jess's family at fkn amazing cooks, curries by the bucket load!
Yeh not a burrito joint, whole bunch of foods but I think the obvious theme is Spanish foods.. And cheap to, feed both me an jess to the point we can't breathe and it's like $20 with drinks.
yeah TOTALLY different :P
mamacita here is like a $200 a head afair (with tequila)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
