I'm considering a skyline again, and I live near knox... crazy?
Not as close as Pat though, so maybe ok?
Driven car seven years as daily. Only bumped into him in first year of ownership. (At intersection of burwood and stud)
I tend to avoid Knox shops after hours. Just drive around it. Ftg road or boronia rd.
Just thought id update my fellow brahs
My options of financing to buy a 34R fell through
So buying my car back off Import Monster and rebuilding the engine and fix stuff then back out on the racetrack hopefully in a few months
f*king YES!
Think you're forgetting the day we got defected by the same cop :P
Nah that cop was tops. Didn't give me fine or Rwc and just told me to throw on some stockies and take it to vicroads!
The one which EPA'd me on the other hand...
See it's sad that you should think of that cop as "tops" simply because he's less of a cunt in comparison to others. He still pulled you over cause of the car you drove, still gave you a bullshit minor to get cleared...Petite making all the shit cops look like angels.
i live like 800m from knox, safe to say I had my headaches
actually off the top of my head got done 3 times within a 1km radius of knox.. probably other things i've forgotten too
got done at narre krispy kremes once, that was f**ked remember when I had to borrow your steering wheel hamish cos the previous owner had an aftermarket one on mine.. broke my indicator thingy taking mine off then had to pay an auto elec $$$ to fix it..
funniest story would be getting pulled over after my cousin said "check out that hot chick driving that car" launched it down stud road, nek minit pulled over fined for wreckless driving and defected for bald tyres - didn't even get to catch up to the girl :(
Edited by UNR33L
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
