Are there any other limitations, like exhaust etc, which you could rectify before the retune?
I havent changed anything, and car has pretty much (engine-wise) got all it needs. just need wanted Trent to do his thang on it, cause im not happy with the way it runs now.
Legs too muscular for skinny jeans :(
Lol, skinny jeans... Just no.
Been driving near the city to get to work lately... So many tards on bikes in skinny jeans, you can see the look of pain on their faces as they bust their nut, and not in a good way.
rolled Port Royale with a thick filter and using a $2 lighter that match my socks (which are visible from my rolled up desert-coloured Levis)... ooo yeah
now you're getting it!
I like to wear hoody jackets when it's raining and cold..... and i aren't no hipster!
I alway wear hoodies. How is it hipster. It's usually the thinner the clothes the more hipster you are. Hoodies are thick
Car club hipsters wear hoodies, not all hoody wearers are car club hipsters. Don't you bastards remmeber grade 3 Maths problems? You must have the other elements to complete the hipster equation.
Aaron is half way there with his iPad mini dash.
Sif half way there. I've been different since I was born.. My skins colour for example
And the iPad dash is a great idea admit it. Lol
different like the 20,868,999 other Sri Lankans on earth?
We are one, but we are many, and from all the lands on earth we come, we share a dream and sing with one voice, I am, you are, we are Sri Lankans
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
