thanks tony i might do. i just dont like heading past dandenong and what not cos of the popo!
well its an auto.... full 3inch kakimoto with (ahem) hiflow cat. rb20 actuator 34 smic, safcii (not tuned yet) sitc(not installed yet)
have a metal intake and pod filter etc, but soon going front mount so im converting to a scotty metal intake and back to airbox.
it goes alright for an stock auto... spent most of my time on the look of the car tho. once that was right then its time to go to stage 2 on the engine.
got a gtr fuel pump ready to drop in too. just want some cheap s15 injectors and then of to trent at chequred for a tune. anything over 200kw will make me mucho happy.
maybe before that ill get stage 2 shift kit.
U don't have to drive brah! I'll pick you up or meet at my place! Make the next meeting! Will be good and change your opinion ov Vic. As I said, it's just half the people in this thread hate the world
Lol shuttup.
Nah he tried literally driving into me where there was no room. So I told him to have some
Patience, then tried telling me that one lane is too lanes, so I told him in Australia one lane is one lane, not like India where one is two. And he goes "you are f**king idiot" in his accent so I started immitating him
Hahaha. The funny thing is western onlookers thinking two Indian guys are bagging each other about being Indian, not realising the diff between you two :P
Refer to my sig lol
How soon do you need injectors?
let me know when the next on is and i might come along bro.... be good to put names to faces.
Refer to my sig lol
no idea what this means.... but no rush for em bloke. 240 on standards or there abouts? well i cant go above 200 before shift kit or box goes bye bye...
Standard injectors should be good for 220-230rwkw
Same with the AFM
So yeah if your stuck with money stick to under that
Same with the AFM
not a stuck thingo, but just taking my time with it... just working down the list of things that are restricting me..
cheers for the advice too! :yes:
Lol that's what I kep thinking. I enjoyed it.
Would you want an ss2 turbo? I have thought about selling it....
Only got used for a dyno tune, 3 weeks on the street, before some guy stole it and blew up my engine
I've checked the turbo stil pretty much new
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
