"After Installation, test drive the vehicle for about 180miles (300km) at speed less than 40mph (60kmh). Avoid any quick manoeuvres."
Son. Of. A. Bitch! Who wants to come for the slowest cruise in the world with me? :P
what did you install?
So no 300km needed? Figure 8s for 30 minutes and that's it? (Where the fark in the Eastern Suburbs can you do figure 8's in a skyline for 30 minutes without 4 HWP cars and Rapid Response Units showing up?)
Any particular kind of oil for run in and also afterwards?
Figure 8's lyk dis?
i cant see the vid as i'm at work
I just did it in an industrial estate...
used the nismo oil provided with the diff then dumped it an put in motul comp 75w150
Why'd ya leave Coles?
Had enough of it and they refuse to move me to another section.
No point in being unhappy in a job while they're treating me like a pawn.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
