Again congrats Toby as per fb
muzzas fuckin love jetskis. fact.
also... took the new golf to the VW specialist to give it a once over and full service before roadworthy tomorrow. park in front of the place, jump out walk into the shop to hand over my keys. Old dude wanting a second opinion on a 17k bill VW charged for an engine replacement in his Touareg is being served, so I wait patiently. Old dude finishes up, walks out. I start chatting to mechanic. Old dude walks backs in and goes "sorry mate, I just backed into your car".
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
That sucks man
worst guy lol
So apparently my housemate's girlfriend is angry because i told her that my cast iron wok needs to be dried after washing or it'll rust. Sif not dry cooking stuff after washing anyway.
apparently its the condescending way i said it. lol.
and she wants to move out.
Your like the hitler of your house aren't you?
i wasn't even mad at first cos I was like "I'm gonna be cuting, welding and flaring that guard as soon as it's regged in a few days anyways..." but then he goes into some tirade about me being illegally parked cos I was too far from the kerb or someshit so he's not liable... so it's on like donkeykong. got his details and set my insurance on him.
This kind of behavior pisses me off though, fair enough he tells you what he did etc, but then tries to be a complete smartarsed flamin mongrel and not pay
I reckon only reason he told you about it was someone saw him do it
A girl I've been seeing has Said she never wants to see me again.
What kind of bag should I use when I kidnap her? Cloth or Hessian?
what are the pros and cons of both bags?
Can they be machine washed?
Lol just get an arranged marriage bro. You'll be better off it seems
The land of goat sphincter rings rug
Why the f**k does tur'kish rug auto correct to that!?
Again, Shan's shiftiness knows no bounds.
However...
Turkey
Turkish
hessian will come apart in a machine mashing, plus it gets all itchy
cloth is better and burns easier to get rid of DNA evidence
ahhhh hahaha remember barbs / flynn?
well basically he is this massive douchebag that everyone on sau hates... he used to always go on about turkey and post massive threads about turkey with 11ty billion pictures and basically annoy the shit out of everyone.
so there was a discussion about changing the autocorrect for turkey to something funny...
nek minnut
the sphincter of the universe
SHAN DELIVERS
awesome one more thing to add to the hoon category.
http://www.news.com.au/breaking-news/national/technology-to-target-vic-tailgaters/story-e6frfku9-1226585731432
I can see it now, 20 meters ok
15 you get a fine
10 impound
5 car crushed..
wonder if they could come up with a camera to fine ppl for not keeping left unless overtaking..
15 you get a fine
10 impound
5 car crushed..
This actually pleases me. Especially fkn trucks
Hate tailgaters with a passion
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
