if I got done for that i'd put up an add for anyone that wants their written off yet still running car removed for free and go and rip a skids in a cop shop carpark.
problem solved lol
This. Do you know how hard it is to have my car stolen? I leave my car in the open because it's insured for 11, which is more than most 33s are going to get selling...no dice. It's like they know which cars are uninsured or low valued :/
My friend has a r33 gts which doesn't have a working window for 6 months. The window is left full open when he parks. Hasn't had anyone touch it lol.
Will be trading it in for $2k. Not sure if buy and flip? People buy 33 n/a's these days?
every cop in vic at street next to mine since friday all to get one dude who may or may not have been armed out of a fkn house who ends up killing himself anyway...
my god aus police are crap. bet over in the US they'd have him out in under 5 minutes dead or alive who gives a f**k you're putting the kunt in jail anyway
Then they get questioned about their handling of the situation because he's dead?
He was a serial rapist and psychopath from the very little I know about it all, they should've stormed the joint the second they knew he was in there alone and killed him on the spot. He threatened to burn the joint down? Give him a box of matches and barricade the doors shut. Job done
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
