Someone save it for me... actually devastated atm looking at these photos..
http://www.pickles.com.au/damaged/item/-/details/C2001--Nissan--Skyline--Coupe/1252333284
How much they offer wreck to you? Wouldn't mind engine and gearbox
Also can you ask racepace how much to modify rb20 actuator for 17psi? Thanks
They usually have a company drive day around this time so hopefully we get to do one
When you getting your E class for a week...your Mercedes benefits are starting to sound like Mohsen's girlfriends.
9k which I suppose isn't as bad, but still.. when you're earning under 20 a year it's a big hit :(
Long story short, this chassis is a nightmare, you know all those stories you find on the internet of cut and shuts and you go "nahh that never happens, just a couple here and there thats it"... well, yeah. My dumbass fault for not having it checked properly and you wouldn't believe how disappointed in myself I am but the only thing I can do now is find another shell, get it checked by Stateroads and hope for the best, then try and sell a roadworthy 32R and recoup my losses, or keep it and build it insane. Good for my reputation as a mechanic as well huh :P
did you buy it from shan? :P
seriosly though, is there some channel to report the people that sold it to you? as in did they cut and shut it and misrepresent it as a real car?
if not... have you thougt about bashing them and reversing the sale this way? I find this to be a cheap and effective way of getting my point across
Great start to my day, stopped in peak hour traffic on Burwood Highway this morning and chick rams up my arse. ashdk;jlhasljkdhsaljdhlkjasdh :rant::verymad::domokun: Car was booked in tomorrow for a few things to get changed over too. Feckkkkkkk
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
