ain't nobody got time for 2nd year maths! (at the basic level, anyway) ;p
besides, it was a literature lecture. cuz i'm an arts student 4lyf.
my aero units aren't recorded in the first place :ermm:
Edited by kaitoukid
I'll take 60% of your salary as commision for the first year then it gradually raises up each year as the economy gets worst. How does that sound guys?
But speaking of engineering being a dead market at the moment, had a mate of a mate that just started his graduate position at the start of this year with Aurecom but got kicked out last month of so. They took in 5 graduates, kept 2, relocated 1 interstate and showed 2 out the door. All because of budget and not winning any bids for projects i suppose, also heard that Aurecom got sued 2mill for something hence the budget....
A few Hr thinks that engineering should pick up in a year or two as it can only get better from now apparently.
my offer is 10k if you find me an engineering job. and wagyu. so much wagyu till you wont touch that stuff ever.
good news. Ive just started
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
