I am? lol what sort of spam? I'll try and sort it out cheers
edit: should be fixed let me know if it happens again
Change your password, that usually stops these things. The bots seem to crack or attain people's passwords and then send out emails to contact list. Unless the issue is with Pat's account...
Ive been preparing my sausage for you man... I love it when an azn enjoys my sausage.
This is actually about the arab sausages i make. Delicious capsicumy goodnesa
omit the capsicum, and use some chicken. could be good.
yeah already done, was definitely my account checked sent items and like 100 emails at 12:30 am lol
as much as i would like some bacon, bacon in sausages would ruin the flavour.
but i'm also opposed to the strong flavour of lamb and beef sausages, though i guess that's what the capsicum is for. a great solution would be just to use pork, but chicken could suffice i guess.
no pork because ayrab.
try wheel tech in Dandy.
done some very cheap prices for Federal for me.
http://wheeltechwheels.com.au/
Thanks Martin! But luckily I managed to source and fit one today already so that's one less thing on my to do list!
Sadly my to do list does not contain strip poker, car cruise, and getting drunk this weekend :(
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
