LOL! Possibly. I'm reading about the Flex Fuel system. I think I might do it.
Honestly, I can't find a good reason you wouldn't do it.
Plug in Haltech with the Haltech e-content sensor.
Also allows you to pimp out the dash with with a racepak or something if you like :)
do it!
make you feel like your driving an f1 car :P
i just wrote up all the parts ive purchased in the last few weeks getting ready for my.. build? and im sure im forgetting parts or am missing parts i still want/need =/
do it!
Tell us! I just got my full 100k service parts for cheepcheep.
oh nice! yeah you would man! lucky :P
well the list ive got is ...
nismo cluster
nismo brake lines
nismo clutch line
nismo super coppermix twin plate clutch
moonface superlap tie rod ends
moonface superlap tie rods
cusco tension rods
cusco drag rods
cusco front arms
garrett -9s
hks actuators
apexi power fc & hand controller
hks extension kit
hks cam gears
dba 4000 T3 rear rotors
kudos 100k service kit
project mu b spec pads
ID1000's
nismo fuel pump
trust oil filter relocation kit
i think thats all ive purchased.. and i still need to get
rear + front swaybar links
rear d bushes
Edited by bluejeans
fuark, that must of been a big invoice lol
to be honest i dont know how much ive spent exactly.. but its been a few parts every week for a fair few weeks now..
just waiting for some parts from jesse streeter / some from perfectrun / and a few other from random places >,<
but yeah just hanging out to get it all done!
That feel when Santa delivers a package nearly daily...... hnnggg.
You better not be installing all that at Racepace :P It'll be sitting here for a week + with all THAT!
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
