Yah, but he didn't muck around when he came to collect it, did a compression test then quick look at body and handed the bank cheque over. Took a hour all up.
Aaron is boss now
See if you get moar attention from da ladies now haha
Boss, more like I'm gonna dress like a complete utter bum and play very loud Chinese music to confuse the f**k out of people to see what kind of reaction I get
my esky drops approx .5 - 1 deg per hour so not really...
you can sear afterwards, works the same, as you are not putting enough cold meat in to drop the temp of all that water.
I have done both ways, however sealing first works better for sous vide as the flavour of the searing penetrates the meat.
even in professional kitchens with propper vaccuum sealers and circulators I seal the meat first
point taken, would probably try it then, BUT, how big is the esky you're using and what brand? and some have terrible terrible heat sealing.
wasn't much you could do about it after wheels slipped :\
makes me not want to take mine on track again now
yeah whenever I see something like that makes you realize how easily they can step out and be uncontrollable sometimes...
what happens with car insurance and tracks anyway?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
