Ha, I had a mate at uni who took his set of $800 rims from his corolla to get some SLIGHT rash repaired... the bloke was a panel beater doing some rim repair work on the side...
Dropped them off and was told he'd be called the next day with a quote, gets a call a few days later saying "They're all done, that'll be $650... Come pick them up when you're ready"
And the prick was threatening to not give the rims back until it was paid in full.
Small claims court with evidence of an email from the bloke saying that he'd call with a quote first... = gets the rims back for "cost price" of $200 and the panel beater gets told to stop being a cock :P
Job was crappy anyway... paint was chipping and fading after a few months.
SO GO TO A QUALITY JOINT!!!
lol.
Pretty similar thing happened to a friend of mine.
Repaired 1 rim at a cost of about 900 dollars, but a new rim would have been 1100. He didn't take it to small claims though.
Agree with you re going to a reputable company. I've seen some pretty crappy jobs.
guy we used at honda was http://www.wheelfixit.com.au/ - i got a quote to do a full restoration on wheels i have personally, was 400$ per wheel, would take 2 weeks, or $150 per wheel for gutter rash which i think he could do within the day.
Can these guys un-buckle rims? My SS-V has a slight buckle in one of the rims but it's actually on the outter lip (not the inside of the wheel that most people have).
Took it to the mob at Moorabin but the bloke said it can't be done :unsure:
The freshly painted rotor you dumbass
What's wrong with that? The brake pad will just take it off anyway...
I always do it, leaves a clean line rather than an imperfect masked circle..
I still don't see how that's funny. It's actually smart - unless he is expecting the paint to stay there..
A lot of rotors actually come out completely painted like that.
Not bad at all.
My DBA4000's came soaked in that rust protection oil from the factory and had black painted centers which extended onto the rotors a bit...
Not once I got a bit of brake cleaner onto them to get rid of the oil :) Goodbye paint.
Yes, the brakes will get rid of the paint themselves, but I still would have covered the majority of it with newspaper and tape to stop the black from getting into the cooling vents, slots and dimples! That wouldn't be cleared by the pads right away...
I'm not sure if they can do that, email and ask :P
Not sure if prices have changed - been about 10 months since I got that last quote
Ever ran your finger nails through the slots to see how much crap comes out? Don't think a little paint is going to be a worry, and in any case the temperatures that the friction part of your rotors see is MUCH more than enough to take the paint off..
It will come off in the first 5 minutes of driving..
Oil is a different story, but paint? f**k masking it..
Yeah I pretty much covered my rotors, came off after bed in and looks neat vs masked ones that always seem to mask around the line in the center not the actual edge of the pad contact area and still end up with a rusted section :/
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
