Who ever it was that asked if someone had 33r front pipes I've got standard one if that's of any help
Who's going to renewal day? I'm bout to head there now
Me :P
Ill let you know in a week or so - got to check my current front pipes out first and if I don't have enough to buy some I might borrow just for a tune if that's alright :P
Me :P
Gets build and tune from RacePace
Not enough cash left for front pipe
/Hamish
Anthony, factory pipe is as useful as crushed pipe really. unless you get a lovely letter from people of EPA.
Just get 3" (or 85mm) front pipe.
I thinks there is a hole in it though.. Not just crushed :/
I should be able to get one before I get it in.
Why not get the squashed bit replaced and then a decently thick bash plate welded to it?
If you got a bash plate put on it, wouldn't it then distribute the force either across the whole pipe (wrecking more stuff), or it would damage the dump pipes/turbos ?
Me :P
yeh no worries mate let us know
Suppose it could, cheap doe.
Now I understand that GTR feel....
the good one or the bad one?!
the one when you drive through china town and they all bow before you as though your the chosen one?
or the one when you drive through Heidelberg West and all the yobbos yell out 'shit car get a v8 mayyyteeeee'
GET A V8 MAYTE
Nope... that feeling of torque when you put your foot down and that pure grip + crazy handling... hnnnnggg, most fun car I have ever owned.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
