No worries, yell out if you're chasing anything else.
Just got a quote from Nissan @@Miguelone
Going to be exy even with trade discount lol
What are these part numbers for hoses? They said I might need em
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
You know what they are brah?
lol... jci IS aami
They're underwritten by AAMI sure, but they trade as JCI.
I'm sure they'd have been terrible in the event of an accident, but in terms of hail, it was literally, claim, show up for assessment, recieve money, buy back wreck.
Being an under writer doesn't mean they are the same company, that's like saying you work for u uBank
true... try tell a customer that though... homeside/BNZ even more so
And my evo is $1000 haha I'm younger than you too and live in a worse suburb..
what's the agreed value though?
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
510 and 520 are 2 of the hoses coming off the front of the plenum for the coolant bleeder/water feed to throttle body. 500 is an alternate part # to one of the hoses I already listed for the heat exchanger. Couldn't find the other 2.
What did Nissan Aus want for everything if you don't mind my asking? Amayama price is just shy of $600 from Japan + whatever shipping cost would be.
Lots of R33's are cheap enough for people to street drift and throw into gutters, so insurance for them is insane-o...
Shannons says it drops down HEAAAAPPPSSS once I turn 29 (1.5 years)... Oh... Jesus, I'm old :|
Trade prices quote was $485.74 for all the hoses
And $392.85 for the heater core
I don't think i'll order the heater core, I got 2 spare ones i think
Wow, hoses are almost $200 cheaper through Amayama D:
not if you have it in the highly modified bracket with all mods covered :/
Ummmm, I think this is me?
Considering I'm listing turbo, injectors, fmic, afm, pfc, fuel pump, stereo, wheels, front bar, etc etc... and he said that all my mods would be covered.
What's the go with listing mods on insurance in the event of an accident if they are deemed to be illegal?
Or does it only matter if it is the 'cause' of the accident?
Is there any point listing them? I spose it would only be good where you are in an accident which is not a write off where they will need to replace all the bits.
Someone aware me
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
