No worries, yell out if you're chasing anything else.
Just got a quote from Nissan @@Miguelone
Going to be exy even with trade discount lol
What are these part numbers for hoses? They said I might need em
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
You know what they are brah?
lol... jci IS aami
They're underwritten by AAMI sure, but they trade as JCI.
I'm sure they'd have been terrible in the event of an accident, but in terms of hail, it was literally, claim, show up for assessment, recieve money, buy back wreck.
Being an under writer doesn't mean they are the same company, that's like saying you work for u uBank
true... try tell a customer that though... homeside/BNZ even more so
And my evo is $1000 haha I'm younger than you too and live in a worse suburb..
what's the agreed value though?
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
510 and 520 are 2 of the hoses coming off the front of the plenum for the coolant bleeder/water feed to throttle body. 500 is an alternate part # to one of the hoses I already listed for the heat exchanger. Couldn't find the other 2.
What did Nissan Aus want for everything if you don't mind my asking? Amayama price is just shy of $600 from Japan + whatever shipping cost would be.
Lots of R33's are cheap enough for people to street drift and throw into gutters, so insurance for them is insane-o...
Shannons says it drops down HEAAAAPPPSSS once I turn 29 (1.5 years)... Oh... Jesus, I'm old :|
Trade prices quote was $485.74 for all the hoses
And $392.85 for the heater core
I don't think i'll order the heater core, I got 2 spare ones i think
Wow, hoses are almost $200 cheaper through Amayama D:
not if you have it in the highly modified bracket with all mods covered :/
Ummmm, I think this is me?
Considering I'm listing turbo, injectors, fmic, afm, pfc, fuel pump, stereo, wheels, front bar, etc etc... and he said that all my mods would be covered.
What's the go with listing mods on insurance in the event of an accident if they are deemed to be illegal?
Or does it only matter if it is the 'cause' of the accident?
Is there any point listing them? I spose it would only be good where you are in an accident which is not a write off where they will need to replace all the bits.
Someone aware me
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
