No worries, yell out if you're chasing anything else.
Just got a quote from Nissan @@Miguelone
Going to be exy even with trade discount lol
What are these part numbers for hoses? They said I might need em
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
You know what they are brah?
lol... jci IS aami
They're underwritten by AAMI sure, but they trade as JCI.
I'm sure they'd have been terrible in the event of an accident, but in terms of hail, it was literally, claim, show up for assessment, recieve money, buy back wreck.
Being an under writer doesn't mean they are the same company, that's like saying you work for u uBank
true... try tell a customer that though... homeside/BNZ even more so
And my evo is $1000 haha I'm younger than you too and live in a worse suburb..
what's the agreed value though?
14056AA510
14056AA520
14056AA505
14056AA515
14056AA500
510 and 520 are 2 of the hoses coming off the front of the plenum for the coolant bleeder/water feed to throttle body. 500 is an alternate part # to one of the hoses I already listed for the heat exchanger. Couldn't find the other 2.
What did Nissan Aus want for everything if you don't mind my asking? Amayama price is just shy of $600 from Japan + whatever shipping cost would be.
Lots of R33's are cheap enough for people to street drift and throw into gutters, so insurance for them is insane-o...
Shannons says it drops down HEAAAAPPPSSS once I turn 29 (1.5 years)... Oh... Jesus, I'm old :|
Trade prices quote was $485.74 for all the hoses
And $392.85 for the heater core
I don't think i'll order the heater core, I got 2 spare ones i think
Wow, hoses are almost $200 cheaper through Amayama D:
not if you have it in the highly modified bracket with all mods covered :/
Ummmm, I think this is me?
Considering I'm listing turbo, injectors, fmic, afm, pfc, fuel pump, stereo, wheels, front bar, etc etc... and he said that all my mods would be covered.
What's the go with listing mods on insurance in the event of an accident if they are deemed to be illegal?
Or does it only matter if it is the 'cause' of the accident?
Is there any point listing them? I spose it would only be good where you are in an accident which is not a write off where they will need to replace all the bits.
Someone aware me
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
