well very generally speaking...
you need 100's of millions to build it, and you need to be in bed with the people awarding the contracts.
Then the government will go on about how it's not govt funded
Then a few hundred mill will be chipped in by the government promising victorians that after the tollway is paid for, tolls will cease
Also a second promise will be made that no roads will be blocked off to force drivers onto the tollway.
the projected repayment is usually somewhere between 10 and 20 years.
the road then opens for free for a month to get people hooked...
then roads are blocked off all over the city to force people onto the tollways.
oh, and 10 years later, after it's paid for.... you keep charging and increasing tolls.... and it's all profit from there on.
Motherf**kers using nek minnut in actual conversation at the desk next to me. All of my rage
Did they even know to use the scumbag kiwi accent?
2009
that shit was scary! remember how awesome it was hitting up the black spur on that first cruise we did after the road was rebuilt?
crazy visability with no leaves in the way and the black trees with tiny green sproouts all over them
There's a bloke at my gym who uses a full on lifting belt around the waist, like a 1920's Russian Strongman...
He's a lanky ~65kg guy with ONLY biceps, and all I ever see him do is lift bicep free weights.
y u belt, bro?
I miss gym :( Living with gf means my gym is too far away... No contract so I could cancel... so I only get a chance to hit it up once a week when I go home, blergh. Can actually feel my muscles getting sore and breaking themselves down after a week :(
Wait wut?
You live with your gf now? That was quick!
Where does she live? And when do we get to see her?
OMG PHAGGOT!!!!!
he removed 18x10.5 TE37's to put on 20x9.5 bob jane specials!!!!!
from this:
to this:308237_10150359742678701_958007034_n.jpg
wtf...
from what looks like great fitment and wheels to absolutely shit
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
