guy that bought my car recons the clutch was fried... lol that thing was 100% when I put it back in with the new motor, it then did maybe 3500km tops...
so the clutch was fried and he still managed to wreck it....sounds like a twat...
How much power you running in the Stagea?
You could borrow my spare set?
Not much at all, prob around 170-180awdkw at most i think but wanting splitfires or OEM so I don't have to replace it in the future when I get more power.
How old is the spare set? Condition?
Buy from perfect run, use gaffa tape for now lol
Will call perfect run, won't rely on gaffa tape lol
Hang on...you're bragging about how few of you got laid on a Contiki tour? :unsure:
bragging?
There were a few couples, and even more werent single ie. left their partner at home. Average age was like 28-29. At least 5 were over 30 which was surprising.
How is that needing them asap?
he either rode the clutch pretty hard for a few days till he wrecked it, or they both happened at the same time...
yeah riding it was my first thought too but sheeet...it wouldn't burn out that quick
so is a dead clutch his excuse for wrecking it?..
thats fine for your own motorbike,,,but its useless for track days,, they check the for the sticker,,,also when you come off and crack your head open like an egg you might have a hard time sueing them,,,,and there is good money to be made sueing them...
I know of 2 people with payouts in excess of 300k ;)
personally ,its not something I would mess with for the sake of a few bucks...
A shoei is a Shoei, so from a safety point of view there is no argument to be made. It's the same helmet, only Australia charges a ridiculous premium for a test inferior to the tests passed overseas, and a sticker. A sticker which can be purchased for $30.
Perfect run, $429.01 + postage.... anyone know if perfect run is reliable with their warranty?
Hoping to get them by this week or next and just incase they weren't my problem from missfiring then I'll have some time to fiddle around before deca. Plus I won't have much time to work it out after next week.
It was a button clutch, if u ride them they wear out very quickly..
contiki tour = overpriced brothel
Agree.
Travel thru europe is piss easy now (thanks to Schengen Agreement/Euros currency).
Parents did contiki many moons ago only cause the Schengen agreement didn't exist back then and went over there 2 1/2 years ago and told me not to bother with contiki tour.
If you want to meet people, do it on pub crawls, job done.
You can just borrow them for DECA till you get your new ones sorted
There off a well looked after motor at around 100,000kms
Changing coil packs is easy takes 5mins. (That's if you have your neo cover and valley cover off) Which I did so it could slightly reduce engine temps
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
