Yep
Spoke to her last weekend, said I'm not gonna have any regrets, so just one last time, do you want to try again?
She said No. Had a bit of an argument, got upset, next day thought "f**k you" and started moving on. Today she messaged me about picking up her shit then wanted me to drop it off, I said No. Of course she started an argument over it and resorted to insults, and I didn't. I didn't give two f**k's, I felt nothing anymore, and I loved it.
Add in the fact that I'm seeing a f**kin cute as f**k chick this weekend, 10 times hotter than my ex... yeah, I'm already happy :P
good! happy for ya bro.
birdmans the best for relo advice.
birds i never told you but i stabbed my ex like you told me in the neck. it worked!
  • Like 1
All mass.
well, yes. but i guess you meant all muscle
was it hard learning to use your other hand?
Oooh, that's an idea. When I go to make my purchase I might ask if they'll let me do just that :D. Yeah with the loosening up considered, I was edging towards the 50. Also it had the insert liner thingy you could take out for summer, which frees it up a little? Plus my cut continues... maybe factor that in... xD.
Cheers for advice though, liking the sit-on-a-bike-there-with-it idea.
yeah should be tight bro, im 176cm 73kg at the moment i'll have to check what size i got
what jeans do you boys have? researching i find some people don't even rate the kevlar haha, think it's a scam. i'm undecided.
however am leaning towards draggin slix or twista... they look the least daggy / can wear at uni XD
ive got 2 pairs of draggins. camo, and normal jean looking ones I like riding with my camo ones :P can wear jean ones if you're like going out for dinner or something i guess
like these :D *pic isn't me* similar bike lol
tonight i rode my supersport over a bmx jump lol damp grass and wheel spin ftw :P
Edited by UNR33L
Are there any of those hipster skinny jeans for motorbike? Would be funny LOL
Haha, both the ones I mentioned are more slim fit, but I don't think they're overly hipster skinny. But some of the others look like adult diapers....
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
