Im not going to bite on the dyno comment... Although I will admit I do want to :P
I don't think you guys appreciate how much difference 400 kgs really is...
For an equal power to weight that car actually only needs 280rwkw to be on par with Leigh, and any more is gravy
If that car makes 350 we are talking approx 270 rwkw / tonne vs Leigh's 210 odd
That is stupid quick....
Although being a commo it probably has 400kg worth of subs :P
still, why is it that 1390kg gtsts with 325rwkw can only pull 12s? :P
there's a lot more to it than just power to weight, gearbox / ratios, diff / ratios, torque, turbo lag, power curve, tyres - not saying it wouldn't be fast though just saying a lot more to it, there's a reason why my brothers light gtst can't get off the line for shit it's too darn light at the back and that thing kills my power to weight even in 2nd it spins as soon as it hits full boost with 275 nt05s lol
Hopefully I'll get deep into the 11s (anything around 11.5 I'd be stoked) at heathcote next month, will have to be careful off the line don't want to break my input shaft or tail shaft lol
Edited by UNR33L
Comes down to car setup clearly, in all cases, but that's an unknown quantity in this car... All we know is power and weight.
You realise this wouldn't have even been brought up if you weren't constantly dickbagging on about your cars power :P
Hahaha yea I know
Then you have overpowered bikes :P
can't get over how expensive seat mounts are... rails are pricey enough. charge $160 for an aluminium set and they don't even drill holes in them.
made my last set, doesn't take long with the right tools. need another set for passenger now, time to get some aluminium
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
