wouldn't be modding it past exhaust / tune really... it's not a race car
a supercharged 2uz on the other hand.... but they aren't in any cars you can import yet :/
You're such a wank u only just bought the car and already want to sell it..
*whistles*
evos must be boring, you aaron and nick all selling/sold after not long :P
kinda.... it's still only 170awkw
i'll do the mods first and see how she goes with 230-240 before I make any real descisions
lol @ Evo owners with the impulsiveness of teenage girls
It makes me not want to buy one cause they're obviously not awesome enough to take priority over almost everything else in life like a Skyline tends to do. Unless it's just you three.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
