there is a nice 6 zero fighter replica in white in nsw, but its probably a bit out of your price range, asking 29.5k
29.5 large is out of my budget quite a bit! :P
Is it on carsales?
woo received my amayama package.
It is in an AusPost parcel and return address is Amayama NSW?? Didnt know they were australian??
They have an office/warehouse/something in Sydney..
Trying to quote things that are on more than one page completely sucks now.
installed clutch and gearbox on Saturday only to have the release bearing shit itself on the test drive and fried a fair bit of the clutch plate too.....fml
Darkside Developments are sending me out a new clutch plate and release bearing for free luckily, however car is still off the road :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
