ok so on the hunt for someone to rebuild my engine...
engine was originally built by midnight mods, all other work done by RE Autoworks (back in 2005-6). My run-ins with RE the last year havent been too fruitful, but I found out on the weekend he has now merged with RTR in Dandenong, who are reputable and seem like nice guys. and Ray knows the engine pretty well, so could be beneficial
So far on my list is:
DrDrift
Forced Motorworx
RTR
any other suggestions?
What about Tony's engine rebuilder?
Michael? He's pretty good, him and his dad have a shop! Should see the one in his garage!
Yeah alot of workshops outsource alot for the engine building processes to specialised workshops. As you need quite specific and expensive equipment.
Michael is an engine rebuilder by trade. So only thing going in that workshop is engine rebuilds non stop!
Workshop is called Headspec in Mulgrave, If you want we can discuss your options over cofee or something one night and i'll ask Michael to come along if his free.
yeah Me and a buddy lifted a (used) 302 off the back of a ute to the ground..worst bit was finding it was a used 302 so we had to get it back on to take back to the shop
FYP
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
