When people say they need to run 1000cc injectors for xxxHP. that means 1000cc each injector right...?
Some noob on ozhonda keeps saying that when people say 400cc is needed for 400hp on E85 on a 1.8L 4cyl. He thinks that its 100cc injector per cylinder...
So he says he needs 1600cc injectors for 400hp e85 n/a, which in his mind means 400cc each injector. Lmao, confews...
It's per injector. Engines with less cylinders obviously need bigger injectors to flow the same as engines with more cylinders. So Nismo 555s in an RB will still flow a bit more than Nismo 740cc in an SR.
400cc injectors will NOT cut it for 400hp in a 4 cylinder engine, particularly on E85. You would need 740cc at least and that may be maxing them out. ID1000s would be a good choice.
yar yar. i confused myself a bit in my post. He said he would need "ID1600" for 400hp, which would be "maxing them out" (in his mind 400cc per injector). We were all wtf, because 1600 more than enough for 400hp. Turns out he meant ID400. Got that stubborn mind where when someone states xxxCC injector, thats the overall CC for the whole engine. Lol
it is a legit fix, rice absorbs the water and fixed the device.
better would be the stuff they package in electronics and such but hard to find in bulk.
make sure device is off, leave for a couple days in rice..fixed.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
