Anyone had a varex long term? Reliable?
Anyone got the optional rpm based controller?
yeh had one.. reliable? the muffler is, not the actual control box and remotes, i went through 2 boxes and remotes..
a few other people have said the same.
Me. No issues here; works like a charm. I usually leave it open though, occasionally switching it to silent and back now and then just to keep the mechanism from sticking.
Didn't know they had an RPM controller. I prolly wouldn't bother with that in a turbo car though; seems counteractive to spooling up.
All these avatar changes i cant keep up with who's who. :(
Few mates with varex exhausts, couple of problems here and there but nothing too major..
On another note, duno why I got so drunk last night and having to pick my mate up from airport this morning :(
at airport now. only here for emotional support and chauffeur. wouldn't mind so much if the mrs' mother wasn't here. would rather be seeing a musical theatre performance... oh wait, I have to do that tonight too.
:| kinda wish I was at work all day.
The emo has a decent sized muffler on it but at idle it is very deep and boomy, the idea being to just have it open above 3k
I can see how this works.
he says it's sold.
askes for your contact detaisla dn bank accoutn to give you the 200$..monies gone.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
