Nice, Leigh! We go for a ride soon! I'll follow 100km behind dw :(
Also looks like my left headlight has karked it. Sigh. It's cold and dark cbf checking it now, but anyone know what it could possibly be? Just a replacement job? Factory xenons.
Also looks like my left headlight has marked it. Sigh. It's cold and dark cbf checking it now, but anyone know what it could possibly be? Just a replacement job? Factory xenons.
Don't worry my bike would be back there to - after I unstick the clutch... again
Who is good with sourcing oem nissan gear? My hicas ball joints are flogged
Outer Ball joint
http://amayama.com/search/?q=55154-0P800
Seal
http://amayama.com/search/?q=00922-13000
Tie Rod end(Though you shouldn't need this)
http://amayama.com/search/?q=55725-0C800
Tie rod
http://amayama.com/search/?q=48521-79T00
/start rant/
stupid sunday early morning drivers, can't fkn do hook turn properly in the city, took out my rear left quater and didnt even bother to stop. lucky it was outside the magistrate on williams/la trobe hopefully theresa some clear footage.
/end rant/
Thanks mang. Will fit 33 gtst?
Pretty sure I won't need the tie rods / ends
/start rant/
/end rant/
goodluck getting footage. they wont give it to you
Those are the gtst part numbers fresh outta fast. If your outer ball joints are darker your tie rod ball joints probably have a fair bit of play in them as well.
Ah, I didn't know they had rubber inside. I'll have a better look
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
