Sad seeing all the young women's on the treadmills and never hitting up some weights. If only they knew how good some resistance training would be for them too. :(
On the plus side some very fit girls doing weight training tonight I was mirin'
I feel there's a swole joke in there somewhere birds.
You are all a bunch of fkn homo's... Not one person commented on the vid Leigh posted... For shame
Some fkn awesome footage right there!
Meh my bike can do 300 and costs much less, and my grandma can shift a manual.
Sif no respect for dem 80s f1 drivers! those mofos basically sat in a Tupperware container pushed the cars hard as fark and died frequently!
I suppose you could say the same for moto gp riders, but they could slow down a lot easier once they came off i suppose - still sad about Marko last year :(
Isle of man TT though.. another story like over 200 deaths in 100 years
Edited by UNR33L
How you set it up? I got a gopro black collecting dust. Wouldn't mind using it for something.
Am paranoid people break in to take it if easily spotted.
Ceebs removing every time I park car.
wired in extra cig socket behind dash and ran the cord that came with camera to behind rearview mirror. works great. now just have to figure out how to adjust date and time because atm in driving in 1970
speaking of cars...
anyone know anybody who might be interested in doing a defensive driving course on the 7th of July for $100?
i might. will get back to you
when i fix the date on the camera i expect there to be hoverboards and shit errwhere. otherwise somebody gonna get a hurt
well that one judging from the quality to get enough speed to actually cause benefit I think would blow apart.
however this is the technology that BMW is moving to for the next M3, triple turbo, 2 normal and one "electric" turbo
so instead of zorst gases spinning the turbo an electric motor does to remove turbo lag.
Hypergear has had a go at developIng something similar to this. Fascinating stuff that a bullshit eBay concept finally makes its way into an effective application!
If it works anything like the Hypergear concept, it's not an extra turbo but electric motor instead spools up the exhaust driven turbo and then clutches out for exhaust to take over.
Wouldn't that be a supercharger?
well technically a supercharger is something fed off the crank.
so it neither really. just an electric fan giving the system slight pressure.
in my books they have missed a great naming operturniy here.
they could ahve gone with
megacharger
protoncharger
supermegaawsome elctro boost system
http://www.topspeed.com/cars/car-news/bmw-files-patent-for-electric-powered-turbocharger-tri-turbo-m3-still-a-possibility-ar119350.html
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
