Is it a track day where you get put into groups then get times laps? Never been to a track myself so please noob it down. :)
yes they put you in groups.
they will ask for any experience when you say none they will look at the car and pick a group.
Auto Stag will be in one of the slowest ones.
then if you are too fast they will reclassify you during the day.
there is normally around 20ish ppl per group
you get a run approx every hour for 12-15 min, (which is all a car with stock cooling can handle anyhow)
so that 6ish laps.
you can have a passenger at any point in the day, so if there some-one you know who has experience throw them in the passenger seat for some advice.
same clothing as deca, long sleeves and helmet, leather shoes, the License you got for deca will work for there as well.
Timing is included, appears on a screen in the pits and is updated to natsoft online so you can check lap times later on.
Bar doing something like a driver dynamics day it's the easiest entry to a track day and the cheapest way..unless you break something!
oh and the melbourne cup Tampered day is going to be part of the MS championship.
Im replacing the whole interipr with a fairly rare black interior that I picked ip super cheap
Power windows needed replacing of the floor loom which connects the doors together along with everything from the front of the car to tje back of the car. So carpet had to come out. Which is interior out job anyways in a civic
So in return I got power windows and a black interior thats really saught after in the civic community. :)
My car is full of them rare parts. Hahah. Definitely will hold its value if I rver decide to part out.
My civic just looks like a stock civic to all you abos tho
because stock wheels.
Because its a civic
Can confirm I have no idea
And will still look like stock civic
And I own a civic lol
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
