very clever.........
no idea tbh. im actually selling my skyline as i join sau...
but once the clubby is ready and i have all the cams gear for the car then ill look! might have a go at the hill climb at nats, other than that havent got a clue! i want something cheap and easy for my first time in the hsv. shes a big girl.
All you need is a cams approved helmet, fire extinguisher and some stickers and off away you go!
As for tracks, IMO Winton is easier for the beginner but Sandown is convenient because its so close
calder in a couple months as well, and this is a pretty good beginner track.
yea not a fan of concrete lol.
wont be going to hard as its my daily hahah! well i have a couple of helmets in the garage, hopefully one of them will work.
have a fire extinguisher in the boot, but yea need to have a bracket knocked up to bolt one to my pasenger seat...
have a magnetic battery sticker, just need one for tow....
would love to do a driver dynamics day as a refresher, but cannot justify 300 at the mo!
Never been to calder park
Is it mostly grass for run offs or concrete walls?
main straigh has plenty run off as it the drag straight, well was last time I was there.
rest is grass then concrete but it all straight line braking. it's really a very simple track.
shit condition tho thanks to 0$ spent on it and drifters.
You'll be fine
My first track day was Sandown in the wet in the daily R34
Just take it easy and you'll be fine!
So i see
Count me in then!
Stolen from his FB
But SAU VIC member Chris Madden has been driving this around.
1016655_10151453840572050_1308600656_n.j
Hnnng. The only thing tempting me to f**k responsibility and blow cash.
/will wait for labour to unf**k FBT so I can salary sacrifice that bad boy.
Must....resist....purchase
seriously tho aaron, you can have my 33 for 4350!
reg till nov! :woot:
ill even help you drop a manual in if you dont like the worked auto.
Lol the only boat I would buy is one that floats on water
Bit of press on the FBT changes
Im curious as to know your understanding and explanation on how and why this effects you?
Just trying to gauge the understanding of the changes from the public's point of view
Aaron you should pay attention as this change will effect you
Along with everyone else on your team that gets company cars!
Company pays FBT, and technically we are paying for the car as its apart of our salary and not as a benefit. Ie I can choose to be paid more and not be given a car..
My understanding is that tax is paid on default 20% private use for a salary sacrificed car.
The changes would mean I need to calc the private:business use; when salary sacrificing car I'm not using it for business but 100% private.
That's my understanding of it.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
