Wait... So is this the car who's owner posted above? Why's it saying in the article that its owned by the Tran twins?
http://www.worldtimeattack.com/index.php/open-class-byp-racing-honda-civic/
(I'm surprised it's not running an SR20... though I guess they do pull a premium before WTAC...)
The article says BYP is owned by the twins
I stand corrected... Article is pretty vague however... If its going to be their promo car, they sure are ripping him off a lot... and if the EG has moved on from BYP, that WTAC article really shouldn't still be there promoting the car... That said, it was probably written over a month ago..
Drove my first Porsche (only a cayman) today. Very low to the ground with small windscreen. Cockpit feels very similar to the s2k.
The PDK gearbox was cool, it rev matched on deceleration & gears changed without feeling anything
Handled quite well and suspension was firm. Could only imagine how much fun it would be with a proper engine :P
I did like the engine being behind, did sound nice when I gave it some poke
they sorely need more power though, they are gutless wonders.
Was considering one as a daily for this very reason! Daily + weekender in one!
Reliability and expenses scare me though!
bosses ones have been fairly reliable (3x cayennes (2 diesel, 1 GTS) + cayman + 911 turbo)
only real issues have been the radio/bluetooth randomly dropping out/not connecting.
Average wage is a rort.... It is skewed by high income earners and not corrected by people on negative income
Median wage is just over $50k which seems somewhat legit.
FWIW the average wage in ACT is $85k (no prize in guessing why)
i dont make the average wage for the ACT.
dissapoint :(
Can confirm driving Euro is a slow death. Current daily is a 2001 auto astra.
Had to put this in my driveway for a day or two to remind me of what its like to drive a real car (even though its technically euro... but I guess so is a honda accord)
yes, but its a euro with a toyota drive line. so its not always broken.
The GPS unit is f**king useless too.
Way to play catch up in Vic wl.
500k borrowed for first home? Is this normal? Don't these hypothetical young couples have a decent deposit?
even my normally fairly broke ass will only be borrowing ~300k on my first place in a year or two. who needs their first place to be worth 500k + deposit.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
