Stock Results @ 14m25s
155HP 127TQ
Perrin Headerback Results @ 15m30s
156HP 131TQ
Ummmmmm, what?
This better do some serious boosts to the midrange, because the Perrin exhaust they installed in this video has a $900USD pricetag?
Am I missing something?
Haven't watched the vid, but I only have a cat-back. It cost me $750 second hand, they're about $1100 new and actually one of the cheaper cat-back options for this car. Made in the USA and nice quality. It would have gained a few kw, I can feel it however if I did the rest of the exhaust it'd gain a bit more. Planning to do the headers, over-pipe, mid-pipe, might need to think about adding a resonator back in as it's already boomy inside the car under any throttle at all and it'd only get louder and dronier. It had 108rwkw stock, 118rwkw with just a tune so with the cat-back added I'd expect it'd be up around ~125rwkw now. Not bad for an N/A 2.0L auto.
fyp for accuracy.
UEL and EL's move the torque band slightly, and although UEL's should lose power they actually don't on this engine. Both make around the same power gain. So realistically it depends if you're looking to eliminate the torque dip or have higher top end and what sound you're looking for. The UEL's do sound pretty hot.
So this happened today...
brakes have been upgraded to GTR ones and they seem to work noice! now I just need to get the biatch started and then nursed all the way to a workshop... or towed to one.
Wo can service a skyline near dandy?
After service... to the paint shop to have the panels all matched up.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
