Sigh... LPG for a power upgrade, not economy
It has a massive RON and I want to run dedicated for 240-250 rwkw, not some shitty duel fuel system.
Not to mention it will be cheaper to run and should be cop hassle free if set up correctly
Any reason for LPG over jumping on E85 bandwagon, convenience I'm guessing?
Does it also have the benefit of keeping your engine cooler like E85 does compared to 98?
From memory, it runs hotter unless it's PROPERLY setup, could be wrong though I looked into it ages ago so my memory is hazy on that.
Yum cha setups are for economy/tightarses and installer tune accordingly.
Thought about it but e85 economy sucks and evo fuel tank is the size of a coke bottle. LPG economy is the same but available everywhere.
It is also legit when you need to explain it to cops.
With intank walbro, 8MR turbo and BOV, highflow panel filter in stock box making LICP the only intake mod and a 3" exhaust with a varex this should leave me just shy of 250rwkw and relatively cop acceptable.
E85 leaves aftermarket stuff visible like injectors without the excuse of it being a non performance, legal LPG conversion and for some reason seems to be killing e7 4G63's
You're planning on dual fuel setup or straight gas?
Totally understand the convenience thing, especially evo tank aren't that big.
May have to run tanks in the boot, couple small ones on each side
Isn't straight gas legally unable to be epa'd, well that's what I heard whether it's true or not
But yeah can't run dual fuel and make power, needs to be straight gas to make more power than petrol
My accountant f**ked me
$7 refund
Anger rising
I've got a $33 due to the ATO :(
What is this? I don't even...
ATO must be crackin down. I claimed a lot and got back less than expected. oh well.
ATO = faggots
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
