blamin the ATO just makes us feel better. it puts a face to the empty promises and hope we all cling to each year. the shadow behind the mask, personified.
I should write a play. 'Phantom Of The Tax Office'
inb4 it's your own money fgts...if you got buggerall or a bill then you paid buggerall tax or have a terrible accountant. Can earn 50k a year and get a 20k tax return if you want the ATO to hang onto it for you til tax time.
Those with less of a return are generally better off because, if they were clever and put their extra monies into interest accounts or wise investments, they made gains instead of the government getting rich off your shit. They technically made ~$90 off Leighs tax return.
And never plan your finances/bills/expenses around getting a good return...unless you can properly plan the return...in which case you probably don't need an accountant to do it for you.
/tobysassistant
The informeter tells me I hit 2.86 bar between shifts, when the auto fails to find the next gear in time for the soft limit. Generally 30psi pulls fairly solidly though. :P
Stock VQ25det FTW.
the skyline had a split vac line to the gate, stuck it on a dyno and it maxed out the dynos map sensor and my boost gauge. so it was somewhere north of 42 psi, the ECU pulled so much timing and added so much fuel it was shooting droplets of fuel unburnt out the exhaust and all over the wall along with a diesel like black cloud, dropped 100kw too for a mere 290kw run.
I had a similar issue a couple of years ago, wastegate line popped off and it ran 3bar+ for a few days (no idea how much as that was the sensor's limit.) It caused the head bolts to stretch and split the head gasket. Still no det, just masses of torque.
hm.
yeah i get what you mean, but the climate in vic is such that, driving a skyline means auto pull over the moment a cop spots you. probably not too worth it to be wasting cash modifying only to return to stock.
then again, might have something to do with me driving a yellow skyline.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
