Breakfast of lazy people :,)
Hahaha too true. Knew a guy who would get up at 3am to go to work as a garbage truck driver; he lived off them...must do something.
I just have em as a snack during day.
I smash them daily
I get up at 4am so ceebs making breakfast when I can inhale one of these :D
Hey that's my car. C u @ prinny Friday. Can experience so f**king power.
sounds good, i'll bring the kebabs...look out 4 da cops brew, dey'll defect u n sh*t coz u drive gtrtec.
  • Like 1
i have fitted by BOV back onto the car, no more hektic flutters, just hektic atmo bov sounds.
also re did the ports on the boost controller, the boost learning was freaking out as the solenoid was setup for external gate and running an internal gate, every time it went to increase the boost it would lower it, and vice versa.
Looks like you've a productive day.
fyp for accuracy.
also to update, still flutters at very small boost, then does it whole psch thing with more decent boost.
Vac line leaking?
Bov gasket?
What else haven't you tried?
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
