I can sorta speak/understand it plus Bengali but yeah writing and reading that...ain't nobody got time for dat!
haha! f**k even learning to write that! you need a cert in caligraphy or some shit!
yeah exactly lol. :P if you needa learn how to speak it tho watch a hindi movie, all you'll need is at least 5 hours to sit down and watch bad acting, a lot of singing and dancing and you're set. >_<
But what about the 3 daughters, dayum.
Check this out, the media already all over the motoring enthusiasts:
http://www.heraldsun.com.au/news/six-people-you-won8217t-believe-could-be-elected/story-fni0fiyv-1226715202378
owned by murdoch, did you see anything but pro liberal coming from them?
Think your really putting to much into it re Murdoch.
Yeh hamish the whole thing is a farce really, not just that guy, but the sports party, shooting party I mean far out should be some kind of standards to be allowed to run surely you must have to have some form of a policy?!
Hamish, your point is valid its not only about money however they wouldn't be cutting it if things weren't in such bad shape courtesy of Labors terrific job of burning down the electorates houses with the genius batts idea, or the school building project which gave schools things they didn't even want!
also voting liberal is not voting abbot, you support the party not the person just like football.
Dezz - don't take this the wrong way but it would make sense the majority of your friends etc voted labor as they are likely similarly minded and employed as you are for the most part. Liberal voters are clearly less vocal as my Facebook had epic amounts of labor lovers which i refrained from commenting on as half of it was to stupid to argue with. My mates all voted liberal but none bothered to take to Facebook and have a meltdown.
Clearly i voted Liberal, always have always will i dare say, but this welfare country has to stop its beyond a joke. Its a bit rich to suggest liberal are leaving the mess when the facts would clearly point to it being the opposite.
anyway time will tell, but i for one am wrapped to have Liberals back in charge, sure as shit couldn't do worse than krudd / dullard.
I have something like 500+ friends on facebook, and I'd say the majority of them are not tradies, so not sure what your point is but ok.
You've said it yourself on here numerous times that you believe we're overpaid and that unions are the devil for protecting workers rights/stopping builders from risking our lives to save/make a buck.
People don't actually think they're attractive do they?
Wasnt just referencing tradies Dezz, my fb is not compiled simply of tradies who voted labor however growing up in the west be it coincidence or not they all basically voted labor. Lalor has always been a safe labor seat and even with a 10% swing still they held the seat comfortably. You also can't deny the union / labor connection whether you want to admit it or not. I don't disagree with everything unions stand for either but ill happily debate the relevance of them these days. The majority of labor voters are of the employee mindset not the employer mindset.
On the flip side people I work with and that I associate with these days none would even contemplate voting labor,
Edited by alr33x
Our union is no longer affiliated with the Labor party. Your mate Abbott will bring back his ABCC which will basically strip us of any rights and have the ability to charge/imprison individuals for daring to have their say against the almighty builders.
You'll happily debate the relevance of unions in an industry you know nothing about?
And your last statement only reinforces my point.
I won't waste my time replying again.
My mine site is union free and is the most pro-safety workplace I've ever been.
Companies don't implement safety because of unions, its because they will get shut down by government/work safe if anyone gets injured.
Companies aren't pressured by unions for safe work practices, its because they know the consequences.
Small companies take risks because they don't know the consequences...
I reckon union plays the safe scare tactic to rally people and get union memberships. After all they are a business and have jobs to preserve...
That's my view only on safety & union only. Can't comment on other things unions do.
saw this video again, constant regret in selling that car :(
Pop pop flamesss ! Need to reacquire monies, so I can acquire mods for mine to also do the same :P
Edit: How much power do you think you were making in that video bro?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
