farkin lol.
claim some kms.... even 2000 goes unnoticed.
claim under $150 for washing clothes.
stationary, small % of Interne bill for 'research and development' as well as after hours email access, small % of mobile phone bill for work related calls when on the go/after hours.
lots of little things can be claimed, and most are fair to an extent. as long as their some sort of reason begin the amount, you can back-up the claim.
go 8mr turbo, cheaper to buy and direct fit
9 turbo needs a fitting kit which is another $100ish, not worth the hassle imo
Hmm, depending on the price one pops up for, perhaps.
Would prefer 9 turbo for sure, however if a cheap 8mr turbo turns up, is the other option.
Did a bit of reading on the HKS 7460's earlier... it seems reliability might be a bit of an issue with them ; but when they're working, it seems they're on the money.
Similar should be 1810ET or 712GTP. Saw some charts, looked like they made pretty decent powah. It's the spool and transient response doe.
But looks like especially first models had some issues and HKS was refusing warranty or some bs.
I got my 8mr from US for $350 delivered
the 9 turbo is still capable of more power than the 8MR
Yes 5-10kw on pump, but imo rather something that just bolts in
Also looking at another few hundred for 9 turbo and then another 100ish for the fitting kit
You can make it up to me by writing articles? If subliminal enslavement is your thing, it goes out to around 800 people...
if i had any spare time out side work i really would!
So the new iPhone is released not much excitement.
I'll stick to my Galaxy 3 for now
yea i knew it was gonna be shit. apparently twice as fat as the iphone 5!
so battery will last 10 mins instead of 20.
when my contract is up im going mokia!
Yeah then again I only use my phone for calls and internet duties
Not like I need a faster phone to do those things faster :/
im getting back to that way.... i check twitter when i have a smoke.... i do use the sat nav tho..
very excited to see what microsoft can do with nokias r'n'd dept.
Checking all dem pics of hot girls your following?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
