farkin lol.
claim some kms.... even 2000 goes unnoticed.
claim under $150 for washing clothes.
stationary, small % of Interne bill for 'research and development' as well as after hours email access, small % of mobile phone bill for work related calls when on the go/after hours.
lots of little things can be claimed, and most are fair to an extent. as long as their some sort of reason begin the amount, you can back-up the claim.
go 8mr turbo, cheaper to buy and direct fit
9 turbo needs a fitting kit which is another $100ish, not worth the hassle imo
Hmm, depending on the price one pops up for, perhaps.
Would prefer 9 turbo for sure, however if a cheap 8mr turbo turns up, is the other option.
Did a bit of reading on the HKS 7460's earlier... it seems reliability might be a bit of an issue with them ; but when they're working, it seems they're on the money.
Similar should be 1810ET or 712GTP. Saw some charts, looked like they made pretty decent powah. It's the spool and transient response doe.
But looks like especially first models had some issues and HKS was refusing warranty or some bs.
I got my 8mr from US for $350 delivered
the 9 turbo is still capable of more power than the 8MR
Yes 5-10kw on pump, but imo rather something that just bolts in
Also looking at another few hundred for 9 turbo and then another 100ish for the fitting kit
You can make it up to me by writing articles? If subliminal enslavement is your thing, it goes out to around 800 people...
if i had any spare time out side work i really would!
So the new iPhone is released not much excitement.
I'll stick to my Galaxy 3 for now
yea i knew it was gonna be shit. apparently twice as fat as the iphone 5!
so battery will last 10 mins instead of 20.
when my contract is up im going mokia!
Yeah then again I only use my phone for calls and internet duties
Not like I need a faster phone to do those things faster :/
im getting back to that way.... i check twitter when i have a smoke.... i do use the sat nav tho..
very excited to see what microsoft can do with nokias r'n'd dept.
Checking all dem pics of hot girls your following?
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
