return flow coolers can support 300
the turbo could be getting choked though if it's in a stock housing... Ric's, old hypergear did this before he replaced it with a garrett... i'd have a good look at this
could also be your china wheels or massive gayness
Wouldn't buy any car from Tassie after knowing what panelshops would do and send down there and the dealers would sell
Going through it now with Maggie, so far no issues. However it's a long drawn out process now, about 3 years
@Plattsy
Mate of mine is going through a super hard time for his PR currently and he is from the UK as well
yea its shocking isnt it!
made a point of speaking to my non australian immigration officer (!) that i was guaranteed acceptance on a last remaining relative visa, and simply chose the partner visa because it was cheaper.
tis dog shite.
Seems my engine has a restriction!
Making 260rwkw on E85, only 8rwkw up from my 98 result...albeit with good gains down low and in the midrange. So something is choking it up top. RP and I suspect it may be the cat converter, so tomorrow it's getting made more "functional" and then retuned.
Could also be return flow cooler. Could also be turbo too small. Could be any of the things that make my car look as stock and legal as possible. Not fussed about top end; I switched to ethanol for the awesome mid range, but would be good to walk away from the exercise with a few more ponies up top if we can sort out the restriction.
What sort of return flow setup you got?
They could of just dropped the exhaust and test if they had time
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
