Yeah been thinking about that too!
It seems to me the easier option straight up if you already have the supporting mods. Then if it's still not what you want, upgrade turbo and you're already on E85 :)
How much did it cost to convert to E85?
And do you know how much it costs to go a full flex-fuel setup? I assume you need a new ECU as well? Dont think Nistune will do it
alcohol is for drinking. oil is for driving.
f**k the enviroment yo.
^^ Pommy prick pretending to be a mullet eating bogan. Just because your dinosaur V8 goes backwards in power on ethanol. :P
With some decent comp and drilling the jets on your carby I could possibly get some more powers out of your clunker Paul...
wadda ya mean pretending?
tank is a tank. dont need more power. just needs a s bigger gun.....
If you have the overhead in your fuel system, it costs nothing... Forget the flex fuel for now, just get on it...
Probably not.
My fuel pump i got serviced about 3 years ago via Sabbadin Automotive. All it said on the invoice was a Hi Flow Walbro fuel pump. Don't even know what model it is
need to go a haltec/link/vipec etc if you want flex fuel. changing to that is quite a few $$$ as its sensor + two tunes + ecu, you would also want the ecu controling boost as you can run a heap more on E85 than 98.
$500 for the tune
My engine already had the supporting mods; I had planned for ethanol eventually a long time ago. Supporting mods = basically just a big enough fuel system. 555s and a 040 will do you safely up to 300rwkw.
Also, fk flex fuel. Just get tuned on United which is consistently E85 afaik. There's one in Clayton and one in Scoresby you can fill up at. Car runs beautifully; I don't even have a wide band.
$500 for the tune
With Flex fuel more so thinking on long trips and the ability to use any fuel you want
So say your driving on a long trip you got 1/4 fuel of e85 left. You fill up the rest with 98octane since there is no e85.
Load up the map for 98 octane
Is it still ok to drive with a mix of 98 and e85 or?
if you want NA power on e85 you need to go 12-14:1 compression, but then you can never go back to 98.
itd be interesting to see if my tuned for 98 ls1 would run on a 10% ethanol fuel... not that id try it... but itd be good to every now and again not have to spend so much on 98.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
